Ford F150 Forum - Forums and Owners Club
Go Back   Ford F150 Forum - Forums and Owners Club > Ford F150 Forum - Help Zone - Ford F150 Problems, Complaints, and Solutions > 2ND Generation Ford F150 1980 to 1986 Ford F150 Trucks > Powertrain Engines, Transmissions & Differentials > 5.8L V8 Specific Topics
Notices
Reply
Thread Tools
  #1
Old 08-04-2013, 12:23 PM
radonpro radonpro is offline
Ford F150 Forum Newcomer
Gender: Male
Vehicle: 1986 Ford F150
Color: Brown/White
Engine: 19841986 351 CID (5.8 L) HO Windsor V8 10hp 305 lb/ft - 4bbl
radonpro is on a distinguished road
Default 5.8 loss of power
My 86 f150 5.8 4v auto 200k mi runs,drives,shifts great until it's put under a load. In drive it reaches about 1500-2000 rpm then bogs out doesn't miss just won't increase rpm or pull it's self off of parking brake. I've replaced plugs,wires,cap,rotor,set timing,confirmed mech adv,fuel pump,confirmed pressure and flow,changed ign mod and coil,egr valve,disconnected exhaust at manifolds,compression test has low of 130 high of 145,checked for vacuum leaks,vac holds steady at 19 in at idle. All with no change in symptoms. Any new ideas would be appreciated.
__________________
Ford F150 Forum | Ford F150 Forums | F150 Forum | F150 Forums
Sponsored links
  #2
Old 08-05-2013, 09:25 AM
Mr Mac's Avatar
Mr Mac Mr Mac is offline
Super Moderator
Gender: Male
Vehicle: 1973 F100
Color: White
Engine: 19751976 360 CID (5.9 L) FE V8 145hp
Mr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to behold
Default
Fuel filter changed as well?
__________________
But the wisdom that comes from heaven is first of all pure; then peace-loving, considerate, submissive, full of mercy and good fruit, impartial and sincere.
James 3:17
  #3
Old 08-05-2013, 10:30 AM
Gender: Male
Color: Brown/White
Default
It has no inline filter just the brass filter at carb fuel inlet and I soaked it in carb cleaner and blew it out
__________________
  #4
Old 08-05-2013, 02:01 PM
Mr Mac's Avatar
Super Moderator
Gender: Male
Vehicle: 1973 F100
Color: White
Default
There should be a filter located around the middle of the truck along the left frame rail. It will take a special tool to remove but they are readily available and pretty cheap.
__________________
James 3:17
  #5
Old 08-05-2013, 04:15 PM
Gender: Male
Color: Brown/White
Default
There is not one between tank and pump. (There is the tank selector valve.) When looking down the throat of the carb I've seen fuel coming from the venturis while power braking. I also ran the fuel line into a can of gas to eliminate clogged pickup screen or vacuum build up in tank. I've rebuilt and cleaned the carb (twice), rebuilt a spare I had in the shop, changed power valve, plugged power valve, raised the float, lowered the float. I set the timing (with vac adv disconnected)to 12 deg (spec is 10) reved engine, it went to about 34. In drive it's at 12 and steady but when I'm power braking it doesn't advance. Possibly not enough rpm.
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
power seat, power mirrors, power pedals hog22 Electrical 2 05-03-2016 03:18 PM
power seat, power mirrors, power pedals permitchaser Electrical 4 08-22-2012 03:40 PM
At a loss???? Help With Jerking / Hesitation.... Jason1300 5.4L V8 Specific Topics 2 08-08-2012 06:41 PM
power jayfuzz Newbie Check In! 4 03-03-2012 03:30 AM
Need more power. Telfair 4.6L V8 Specific Topics 0 10-13-2011 05:24 PM
Advertisement
Powered by vBulletin® Version 3.8.10 Beta 1
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
vB.Sponsors
= Copyright F150ForumZ.com a Gigathreads.com Network Site =Ad Management by RedTyger
