Ford F150 Forum - Forums and Owners Club
Go Back   Ford F150 Forum - Forums and Owners Club > Ford F150 Forum - Help Zone - Ford F150 Problems, Complaints, and Solutions > 5TH Generation Ford F150 1997 to 2003 Ford F150 Trucks > Powertrain Engines, Transmissions & Differentials > 4.6L V8 Specific Topics
Notices
Reply
Thread Tools
  #1
Old 07-29-2013, 03:57 PM
saltydwg saltydwg is offline
Ford F150 Forum Newcomer
Gender: Male
Vehicle: 1997 ford 150 xlt 4.6
Color: red
Engine: 19971998 281 CID (4.6 L) Triton V8 220hp 280lb/ft
saltydwg is on a distinguished road
Default Fuel pump problems 1997 f150 4x4 xlt 4.6
My fuel pump won't work.
This is what I have checked:
20 amp fuse good
New fuel pump relays (3)
12 volts to pt. 30 on relay box
12 volts to pt. 86 on relay box when key is turned on.
checked inertia switch ok plus bypassed
Hooked up tester to plug at pump.
When switch turned on 12 volts for one sec. then goes to 6.6 volts.
Pulled relay and jumped pt. 30 to pt. 87 on relay box.
12 volts at pump plug and stayed at 12 volts
Pump runs when hooked direct.
What next? Help Help Help
Thanks,
Saltydwg
__________________
Ford F150 Forum | Ford F150 Forums | F150 Forum | F150 Forums
Sponsored links
  #2
Old 07-30-2013, 08:40 AM
Mr Mac's Avatar
Mr Mac Mr Mac is offline
Super Moderator
Gender: Male
Vehicle: 1973 F100
Color: White
Engine: 19751976 360 CID (5.9 L) FE V8 145hp
Mr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to beholdMr Mac is a splendid one to behold
Default
The PCM only provides 12 VDC to the fuel pump prior to startup in order to prime the fuel rail and then voltage is dropped until the engine is running and then the voltage steps back up.
I have to assume that the truck isn't running? Have you replaced the fuel filter on the left frame rail as well?
__________________
But the wisdom that comes from heaven is first of all pure; then peace-loving, considerate, submissive, full of mercy and good fruit, impartial and sincere.
James 3:17
  #3
Old 07-30-2013, 10:11 AM
Gender: Male
Color: red
The truck is not running.
The fuel tank is out.
Changed the filter.
Going to put fuel tank back in since I know pump runs.
Could the pcm be bad since the power to pump is 12 volts for a split second?
By the way where is the PCM located?
Is there something between the key switch and the relay that could go bad?
Truck ran fine night before problem, next morning it wouldn't start.
Saltydwg
__________________
  #4
Old 07-30-2013, 10:21 AM
Gender: Male
Color: red
The electrical diagram for fuel pump shows key switch to fuel pump relay feeds the PCM and fuel pump. While feeding PCM it energizes switch to close pt. 87a to pt. 87 on relay.
Stumped
Saltydwg
__________________
  #5
Old 07-30-2013, 01:49 PM
Mr Mac's Avatar
Super Moderator
Gender: Male
Vehicle: 1973 F100
Color: White
Default
Start from the tank and work forward. Make sure, with power applied, the pump is picking up fuel and pushing it through the fuel line to the filter. Check past the filter if that was good to the fuel pressure regulator and then closer to the injector. There should be good fuel pressure all the way through to the injectors.
__________________
James 3:17
  #6
Old 07-30-2013, 02:29 PM
Gender: Male
Color: red
My fuel pump won't stay on long enough to pump fuel.
The pump just comes on for a split second and shuts off.
Even if I turn switch off and on.
Even if I leave starter turned on.
__________________
  #7
Old 07-30-2013, 07:47 PM
Gender: Male
Color: red
Default
I guess I'm not the only one stumped.
__________________
  #8
Old 07-31-2013, 10:06 AM
Mr Mac's Avatar
Super Moderator
Gender: Male
Vehicle: 1973 F100
Color: White
Default
I had thought the pump was still out of the tank where you could apply a constant 12 VDC to it to ensure it isn't clogged or anything.
__________________
James 3:17
  #9
Old 07-31-2013, 10:30 AM
Gender: Male
Color: red
Default
Good thought Mr. Mac.
Tank not installed yet.
Will remove pump from tank and immerse it in gas to see if it will pump gas.
Pump runs but don't know if it pumps gas, Duh
Get back to you later Mr. Mac.
__________________
  #10
Old 07-31-2013, 12:33 PM
Gender: Male
Color: red
Default
Pump runs with 12 volts direct, constant pressure and pumps gas.
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
89 ford f150 fuel problems lmdelorme 5.0L V8 Specific Topics 1 07-06-2013 07:50 PM
Fuel pump relay everettdale Electrical 2 06-28-2013 04:53 PM
0 fuel pressure with new fuel pump and filter - any ideas???? dajohns2 Ford F150 General Discussion 2 03-09-2013 12:06 PM
no power to fuel pump jkredwing 4.6L V8 Specific Topics 0 03-06-2013 04:51 PM
Help with Fuel Tank pump wmtelsr1 Electrical 4 04-22-2012 11:41 AM
Advertisement
Powered by vBulletin® Version 3.8.10 Beta 1
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
vB.Sponsors
= Copyright F150ForumZ.com a Gigathreads.com Network Site =Ad Management by RedTyger
