I just bought a used f150 with no manual and i'm trying to debug why the motor that moves the temp control door is not working. Does anyone know where i can find the fuse box diagram?
thanks
tim
Welcome aboard, Tim!
See if this helps...
Mac,
Thanks I replaced the fuse and the blend door moved so to allow heat into the cab. I'm trying to figure out which component on fuse 5 is blowing the fuse, probably not the blend door. will try the back up lights first.
Digital Transmission
Range (DTR) Sensor
(A/T), Backup Lamp
Switch (M/T), Daytime
Running Lights (DRL)
Module, Speed Control
Servo/Amplifier
Assembly, Heater-A/C
Control Assembly,
Blend Door Actuator
thanks again
You're welcome. Just keep us informed of your progress!
