Have a 2004 F150 when fist start up in the morning after the rpm comes down I get a rought Idle but as the engine gets warrm the idle is smooth. if I hold the rpms back up to 1000 when cold the rpm's go up and down a little but runs fine when warm. Had it in shop and could find nothing wrong except on #3 showed a miss when cold, replaced coil pack and plug but still the same. Help !!!!
thanks for the information, I unhooked the battery cable as you suggested but didn't make any differance. forgot to mention fist post they also checked the injectiors and run a somke test which proved all good, checked also for vacuum leaks they said never found any or detected any, thanks for Your reply
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Ford F150 Forumz
