I have a 1995 F150, 4WD, 4.9L with 156000 miles. The problem is with the vent damper. When I am set to "MAX AC", the damper will shift from blowing thru the vent to blowing to defrost after about 30 seconds.
I have looked all thru the Haynes manual and what info I received with the truck, but can't find what controls the damper.
1: What is controlling the damper (PCM or directly from the selector switch?)
2: Where is the damper located exactly?
Thank you
The damper switch is electrical and the switch itself could be the issue. The door I believe is vacuum operated in which case you'll need to verify the vacuum hoses aren't leaking.
