I started to have some brake problems so i started by checking the pads and calipers. The pads did not look bad but the calipers did along with the rotars so i just replaced pads calipers and rotars all at once. After installing i bled the brakes like im supposed to and i had like no brakes. So after talking to a mechanic friend he said i should bleed the back brakes so i did that still nothing. So then i was told it was probably the master cylinder so i replaced that. Still after all of this and bleeding the brakes my brake pedal when started goes straight to the floor. When the truck is off i have good pressure that holds once it pumps up. Does anyone have any idea what could be going on with my brakes?
