Recently my headlights stopped working. I have a 2003 supercrew v8 4.6. Started when I turned put on the right turn signal. Lights went out but turned right back on. Worked for awhile then did it again but as soon as I turned off blinker they turned back on, again it was when I turned on the right turn signal. Then I had the auto lights on and the lights just went out so I turned the switch to the on position and they came right on. I changed the switch and checked fuses and the problem still exists. Everything works but the headlights. I can put on the high beams on the flash to pass. Did that so I could get home. Any help will be greatly appreciated. Thanks
