Hi. I have looked for the solution for this problem.
The magnetic latch that holds the fuel door is broken. You know the one-push it once, it extends and you open the fuel door. Push it again, it catches the door and holds it in a closed position.
Well, the darn thing no longer holds the door closed! I tried taking the latch out to see if I could fix it, and that didn't work.
Do I have to make a trip to the F-150 junkyard to pull an old working one out of a junked truck or is there another option?
