hey everyone! im new here, just started today. so lets get to it, i was working on my 1985 fi50 explorer today and the previous owner put offroad lights on it...crapily...so i was pulling out all the wiring and rats nests for them, and when i was done i decided to fire it up...power to all accesories, windows/locks/lights/dash indicators/stereo, but the starter doesnt turn over. is this easy to fix? and i have a push button, would it be easier to wire the push button to the starter? and one more thing, if i wire the pushbutton direct to the starter (so it cranks when there is no key) will it turn off when the key is turned back? ill mention im new to automotive mechanical work, but i think with the proper guidance i can figure it out. is there anyone here who has any experience and may be able to answer this plethera of questions im bombarding you with? thanks alot.:eek:
As for the starter, it seems like a simple disconnected wire to the starter relay or perhaps the fuse is dislodged.
As for a push start, most newer vehicles use the on-board computer to allow a single button to act as starter and ignition since you use a single button to start and stop the engine. On older vehicles a push button starter would operate like days gone by where you still need to use a key to allow power to the engine and remove it when you need to shut it down.
