I am new to this web site, I found it due to researching my fuel tank problems. I should say I have narrowed it down to the front tank fuel pump or the front tank fuel pump, I don't know enough about the switching unit to know if that could be the problem instead of or including.
I was driving to work and the check engine lght came on and the engine hesatated and then began to run ok and the check engine light went out I drove the 35 miles to work just fine. I statred for home in the afternoon and the check engine light cames on again after less than a mile of travel, I had the same lack of pick up and then it took off. I drove about 25 miles (Stop and go and freeway) and the engine quit and I pulled over and looked at the engine, seemed like the thing to do. I found no over heating oil level good. I then thought that it could be fuel so I switched to the rear tank and the engin fired up. I got to a station and added 5 gals to the empty rear tank and went home. Next day the same problem with the rear tank and check engine light, I experence the engine quiting but the hesatation. I parked it and got a ride to work.
Has anyone had this same type of problem?
I read online that the fuel relay could be bad so I replaced it, only foreteen $ could work. The truch has 299 plus K and this motort was put in with 70 K on it 4 years ago according to the shop i bought it from.
William
William
