i have a 98 f150 did not use truck for about 3 months when i did it was very very hard to shift out of park so i sprayed down linkage finaly free still very stiff same with floor shifter for 4x4 now no 4x4 checked fork and pin going to actuator ok checked solenoids good vacumm to dissengage not so good to engage solenoid both click when i put a 12v lead to it also checked range finder in transfer case ball moves in and out easly tranfer case ok drive shaft engaged can it be transmission leaver sensor or the G.E.M. and how do i check the last two things any help would be more then welcome thanks DOM
