I have a 2020 f 150 4x4 xlt the key will not come out of the ignition it will start runs fine but when you try and get the key out won’t turn back far enough to release it it’s in park but lite on dash for park does not lite tried moving the steering wheel and all that jazz no fix any ideas.
If you have a column shift, have you tried lifting the shift handle up a bit more to see if it will allow you to release the key? For a console shifter the same may apply. Either way it sounds like the shifter linkage may be out of adjustment.
