The biggest issue about lifting a 92 Ford is the I-Beam suspension. There are lift kits available but simply adding a spindle lift would throw it all out of whack causing a lot of issues.
i see what your saying, and thats why i just want to do a spindle lift, because it only affects the disc brakes and rim, everything else is stock.
i am not familiar with fords, i work on old chevys
im just wanting to do 2" coil spring spacer, and a 2" spindle lift, the rear ill use blocks cause i already have 2"of lift on the rear from helper springs
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Ford F150 Forumz
