Hello all, newbie here working on a friends 4.6 f150. the thing died in a parking lot just after running fine. I guessed fuel pump (185kmi) . Tested relay, fuse, and spark. All good. Noticed no gas gauge with key on while towing to my place. Also no sound from tank with key on. Replaced pump and now not only no pump or gauge but no instruments or lights on panel with key on. I have 12v at pump fuse and relay terminal 30 but no v at the terminal that actuates relay. I thought it might be ignition switch but the radio works in on pos. I checked all the grounds I could see and all are good. Seems like all that is left is a control module somewhere. Also checked that crash shutoff for pump and it seems fine. Any idea's would be really appreciated. Oh yeah, checked all other fuses as well. Thank you.
