Hi this is the code my 2000 f150 is throwing. 5.4 2wd auto. So I reset the code and drove the truck and took it to have the inspection done. Funny thing is it passed with no problems. I do know that they test the cap so we can rule that out. Where is the sensor that throws this code? I need some ideas on what to do or what has fixed this problem in the past for yall.
Thanks Jeff
Welcome, Jeff! See if this helps...
DTC Code P0445
DTC Code: P0445 Description: Evaporative Emission System Purge Control Valve Circuit Shorted Probable Causes:
  1. Sensor or solenoid faulty
  2. Connector terminal contact is damaged or corroded
  3. Wire harness - Check harness for correct voltage, open, short to ground or short to voltage
  4. Update control unit software - Check for the latest control unit update
  5. Powertrain or Engine Control Module faulty
  6. Vacuum leaks, damaged hoses or improper routing
  7. EVAP system - Check fuel cap, canister, valves or components
