Hi guys. My driver side power seat, power mirrors, and power pedals stopped working the other day. My first check was the fuses, both were fine. After reading forums regarding this, here's the fix!
Remove the kicker panel and running board panel on the passenger side. about 6 or 8 inches below the fusebox in the wire cluster, is a 3-wire splice. ORANGE WIRES, GREEN STRIPE. The tape they used at the factory has corrosive qualities, so the wires corrode and break. This was the case for me.
Clean up the wires and solder them back together. Tape up your new connection, and you're off to the races!
