Had a very worrisome rubbing noise or chatter in my 2001 F-150 4X4 Off Road that occurred only when making a low speed turn. After much trouble shooting, the problem was in the rear differential clutches. Replaced the clutches and associated hardware. Cured the problem so if any of you have this same type noise in your truck that occurs only when turning at low speeds, then check out those differential clutches.
