Have what I thought was an easy question...but it may be more complicated that initially thought. I have a F150 FX4 with a 2 inch leveling kit installed. I have 20 inch Ford rims on it and want to know the max tire size that will fit and be safe. I have been told 275/65R20 will work...but last night I was told that the max for the ABS system is 275/60R20. So, what is the max size that is safe? Thank you!
The best source to answer that is a local tire shop. They can guide you through selecting the right tire and size for your applications.
the abs has nothing to do with your tire size. One thing to keep in mind though is when you change your tire size your speedometre will not be accurate anymore,
