Ford's oil monitor system is designed to keep you aware of the status of the vehicle’s engine oil and will alert you when it's time for an oil change.
An electronic system monitors the engine operating conditions including temperature and engine revolutions as well as mileage and time since the last oil change. Your message center will then periodically notify you regarding the percent of oil life remaining as well as when the oil needs to be changed.
All of this is designed to help prevent premature engine wear by notifying you of exactly when the oil needs to be changed. It also saves you time and money by avoiding unnecessary oil changes.
