I have an 2006 f150 super crew lariat. I have discovered water leaking into my cab on the passengers side coming from under the dash area. I usually only notice this after it has rained and i'm pulling away from where I parked. I'll hear water slosh and then see water drip (sometimes quite a bit) from under the glove box area. Any ideas how so solve this so my floor doesn't rot out or I don't fry some of the electronics in the dash.
Most likely place to look is between the fender and the firewall. That joint should be tight with a seal. If there is a gap then there is your leaky spot.
